S197 Wheel Width, Backspacing & Offset
Old Apr 10, 2008 | 11:41 PM
mhconley's Avatar
mhconley
Default S197 Wheel Width, Backspacing & Offset
OK - I found a neat little chart for converting backspace to offset:
You can get a ballpark converting offset to backspace just by working backwards.
Now my questions. Assuming you want to keep the tire and wheel tucked under the fender:
[ol][*]What is the widest wheel you can put on the front of an S197 Mustang? 9.5"? 10"? 10.5"?[*]What is the widest wheel you can put on theback of an S197 Mustang? 10.5"? 11"? 12"?[*]What is the required offset or backspacing for those widest wheels?[/ol]
TIA
Martin
Old Apr 11, 2008 | 07:43 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: S197 Wheel Width, Backspacing & Offset
Saleen uses 9"s and 10"s on some S197's and don't stick past fenders. With the proper off-set, you could probably add 1/2" to either and would still fit underneath (but be pretty close). I believe the off-sets are around +24 (front) and +39 (rear), but CONFIRM THIS!
I recommend going to Saleen / Roush section and will see many S197's with 9"s and 10"s. You will be able to see the spacing around wells (keep in mind that they are nearly ALL 20" wheels on those cars)and see if you like it. I think 18"s or maybe 19"s will be a betterfit than 20"s.
Jazzer
jwog666
Dec 27, 2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
