TPMS Training
Old Nov 23, 2008 | 09:28 AM
plutnicki's Avatar
plutnicki
Default TPMS Training
Quick question about TPMS training. I found the training doc online (204-04-1), and I purchased the tool (Motorcraft TPMS-19 Transmitter). My purchased wheels are stock 17s (mine came with 18s) and the overall diameter is the same. I have an SCT Tuner. I purchased used TPMS sensors online and had them installed when the winter tires were put on the rims.
1. I assume these things are powered by the wheel moving, will I need to drive the car around a bit to wake up the new sensors so they have power for the activation?
2. The last step of the instructions suggests using a scan tool to get the new sensor IDs, and to clear any DTC C2780, cause the SJB to exit the manufacturing mode and make sure there are no other concerns with a newly programmed SJB. I don't plan on recording the new sensor IDs, and I'm not installing a new SJB, do I need to do this step? Can my SCT tuner read and clear DTCs (I've not used the function before)? I'm assuming once I've programmed the new sensors, any trouble codes would clear themselves?
3. Any other tricks, tips or common problems I should be aware of?
Thanks!
Old Nov 23, 2008 | 11:13 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Look up top of this section and will see a thead on TPMS. Look in there and see if you can find some answers. My New Edge don't have dem buggers
HTH
Jazzer
Old Nov 24, 2008 | 02:15 AM
Stoenr's Avatar
Stoenr
I know the tool or driving will wake them up. Cant verify part 2
Old Nov 24, 2008 | 06:45 AM
Jazzer The Cat
Retired Moderator
I would hate to think my TMPS is sleeping on the job
What if I had low tire pressure and was out cruisin' the highways at 125 MPH and my TMPS was out partying all night and crashed out?
..... do you think the judge would buy my ride has TMPS syndrome
Jazzer...... speculating
Old Nov 24, 2008 | 01:04 PM
Stoenr's Avatar
Stoenr
Lol, centrifugal force wakes it up, so just a block or so of driving.
Old Nov 29, 2008 | 03:31 PM
plutnicki's Avatar
plutnicki
Just to follow up my own thread, in case of future searches.
My TPMS sensors woke right up, and when I was finished the DIC said programming complete. The car was never actually run without TPMS sensors. It really is just as easy as the instructions make it out to be... So far anyway.
Old Nov 29, 2008 | 09:03 PM
Jazzer The Cat
Retired Moderator
Thanks for following up on your post. It will come in handy to someone
Jazzer
Nick Oliver
Oct 17, 2018 04:22 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
ctgreddy
Sep 20, 2015 08:35 PM
