clearance
Old Nov 29, 2008 | 02:16 PM
fast stang15's Avatar
fast stang15
Default clearance
will a 275/40/17 fit on the front of my 97? BTW the backspacing all the way to the edge of the tire is 6 inches.
Old Nov 29, 2008 | 09:07 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
What the?????
I just posted and didn't work, I guess. Anyway, that tire will run up front but maxed out on room. Especially if you are lowered. My 9" set of wheels run a 275/35/18" and rub on the liner and fenders are VERY rolled for clearance. You will very likely have the same issues as I think my back-space is 5~7/8"
HTH
Jazzer
Old Nov 29, 2008 | 09:13 PM
fast stang15
ok well im not lower so maybe it wll not rub. and how hard is it to roll them?
Old Nov 30, 2008 | 09:48 AM
fast stang15
these are the wheels. they are made by OZ Racing, i think the model is futura.
Attached Thumbnails clearance-pic-0029.jpg   clearance-pic-0037.jpg   clearance-pic-0033.jpg
Old Nov 30, 2008 | 12:02 PM
Jazzer The Cat
Retired Moderator
Rolling the fenders can be a little tricky. I would suggest you just have it done BEFORE hand as you may damage tire/fender if it hits while turning sharply on the road. It may catch fender and be too late.
Install the tires/wheels and check for clearance specifically on the front corner. There is a sharp edge and will be closest to tire, Turn the wheel all the way and see. If it is closer than 1/2" you will very likey hit.
HTH
Jazzer
Tivo304
Aug 28, 2023 12:19 PM
vincep99
Aug 30, 2015 11:42 AM
92 5.0stang
Aug 13, 2015 06:46 AM
91LXstanger
Apr 5, 2005 05:01 PM
baddass92gt
Feb 25, 2005 11:49 PM
