wheel adapters????
Old Nov 26, 2008 | 10:36 AM
fast stang15's Avatar
fast stang15
Exclamation wheel adapters????
does any one know if just the regular aluminun wheel adapters will work with the occasional burnout. or should i get the billet aluminun? also if anyone can tell me a good place to get 5 Lug 4.5 To 5 Lug 4.75 for a decent price could u let me know?? Thanks Justin
Old Nov 26, 2008 | 12:20 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
I DON'T recommend you use 4x5 bolt adapters. I think they are far more likely to come loose and hence be unsafe. I have about 3 or 4 other good reasons, but don't want to list them all
I run 1/2" spacers on rear of my ride, but are just spacers and not adapters. I have also installed longer/stronger lug-bolts and not at all concerned with any safety issues whatever. I think mine are billet, but as long as it is solid aluminum, they will be fine. Besides, I think the only way to make them is billet, but am not sure.
Jazzer sorry to burst fast stang15's bubble
Old Nov 26, 2008 | 01:18 PM
fast stang15
ok i think im going to get billet 4 the back and aluminum 4 front.
Old Nov 26, 2008 | 01:41 PM
Jazzer The Cat
Retired Moderator
So sounds like you will go with spacers that have only holes and NO studs? You will need to replace your wheel studs with longer ones so they will still give adequate threads for lug-nuts.
Are spacers for clearance issues or looks?
Jazzer
Old Nov 26, 2008 | 01:46 PM
fast stang15
no they r adapters. im going for the stock hub pattern (5x4.5) to a (5x4.75) wheel.
fast stang15
yes they r the ones with the studs in them.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
