pics needed
Old Dec 2, 2008 | 11:16 PM
symonds86's Avatar
symonds86
Default pics needed
i got a deal on a pair of 17x10.5 bullits does anyone have a pic of this size rim on a fox? and what size tire are you running on them? i know i will have to do some massagin and remove the quad shocks and exhaust. thanks in advance
Old Dec 3, 2008 | 07:01 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
You won't fit them on a Fox unless you do some SERIOUS massaging, as well as, lose your quads.
This subject has been here a few times as late as a week or two back, so do a search. I have also seen that American Muscle advertises a set of 10"s for the Fox, but don't see that fitting without serous work either. Look up 88Mach1 in your search for replies in this section. He has 9"s out back and was able to run them without too much problem.
HTH
Jazzer
Old Dec 3, 2008 | 04:31 PM
symonds86's Avatar
symonds86
yeah i will search some more i have seen them run on foxes but no one ever says what size tire they run, im not worries about haveing to make them fit the car coming apart for a new motor and getting painted so i figured this wwould be the time to do it
Old Dec 3, 2008 | 07:40 PM
Jazzer The Cat
Retired Moderator
^ Agreed. If you need to do tub-work, that would be the time to do it.
If it works out, come back and give us a write up as to what was done. If you do that search I mentioned, you will find a link that 88Mach1 posted a couple weeks back and had a write-up of installation of 10"s. Builder did tub work and had lots of pics as well.
HTH
Jazzer
drfister
May 3, 2018 10:38 PM
Jskeezy84
Sep 8, 2015 01:40 AM
WDScott
Aug 17, 2015 06:38 AM
defarmer
Aug 13, 2015 06:40 AM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
