Used mt drag radials
I was checking craigslist for some cheap wheels to buy and so i could but some drag radials on. I came across these:
http://sfbay.craigslist.org/eby/pts/963899414.html
I figure they should fit fine in my 2005 gt right? I know they have the same bolt pattern and it being only an 8" wide wheel i shouldn't have to worry about backspacing issues. Would these be a good pick up for me?
They should fit fine, but may be close to fender. Contact seller and see if he/she can give you a back-space measurement so you can compare to existing wheels and do the math.
I know the S197 offset is greater than the Mach 1 by, I think, 15mm (roughly 3/4" or so). Go ***HERE*** to see how this measurement is taken if you don't already know.
HTH
Jazzer
HTH
Jazzer
09-15-2015 07:34 PM
