Will rims from a 99 fit my 2007?
As the subject says. I'm looking to pick up a couple rims to mount some drag radials or slicks on for track use. I always see cheap rims for sale from the older mustangs. Will they fit? If so, How big of a tire can I use?
As long as you don't go over 9" wide, you won't have any problems. The off-set differs from earlier years so wouldn't recommend going 10"s. The off-set greater on the S197's so the earlier wheels will be moved outward.
As for tires, an 8" wheel is good for a 245 or maybe larger if you go higher profile DR's.
Jazzer
Jazzer
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
