wheel spacer on fornt only?
Old May 8, 2009 | 11:31 AM
87slutstang's Avatar
87slutstang
Default wheel spacer on fornt only?
could i run 1/4" spacers on the front only? I need to clear the front strut, but the rear is okay.
Old May 8, 2009 | 02:26 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Yes, you can
I would not recommend anything OVER 1/4" without longer studs. I run 1/2" ones out back but installed extra-strength/length Moroso ones out back. I now have a full 1" of threads for the lug-nuts.
Jazzer
EDIT: Keep in mind that you MAY rub on strut over a heavy bump anyway. 1/4" may not be enough to clear in such cases.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
