ft end alignment ?
Old Mar 31, 2010 | 01:23 PM
skully1's Avatar
skully1
Default ft end alignment ?
i've replaced the wheels and tires on my 08 gt with 18x9, 255-45-18s and 18x10, 285-40-18s. i'm planing on using the k-springs (1.5" drop) front and rear.
with this combination, will i need to have the front end re-set, or will it still be with in alignment?
Old Mar 31, 2010 | 08:12 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
You should gain a bit of neg. camber, but not sure how much. If you are real concerned with getting the most of your tires in terms of wear, you will need to correct alignment a small amount.
Jazzer
Old Apr 3, 2010 | 03:04 PM
skully1's Avatar
skully1
thanks, would this be a standard alignment, or would i need addition parts ?
Old Apr 3, 2010 | 07:14 PM
Jazzer The Cat
Retired Moderator
You cannot adjust the neg. camber via the struts, so you can install a camber bolt that will give you the adjustment you need to square the tires up.
Camber adjustment bolts
Jazzer
Old Apr 5, 2010 | 01:28 PM
skully1's Avatar
skully1
thanks for the info and the link. i've printed it and placed it in my folder for quick remenberance.
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
