Thinking about getting some 18's in the rear with 17's front
Old Jan 19, 2011 | 02:42 PM
Andy13186's Avatar
Andy13186
Default Thinking about getting some 18's in the rear with 17's front
I have an 03 GT with stock bullitt rims, i belive they are 17x8 with 245/45 tires. I want to get some wider rear tires and was thinking mabe a larger rear rim. I did some research with this calculator http://www.rimsntires.com/rt_specs.jsp and found out that there are no tire combos that would be the same size as 245/45/17's on a 18 inch rim. Should i just stick with 17s rear?
for example
my tire height with the 245/45/17s is 25.7 inches.
for a 305/30/18 the tire height is 25.2 (305 35 18 is farther from 25.7)
for a 305/35/17 the tire height is 25.4 (305 40 17 is also farther from 25.7 than this size)
Do the tire heights need to be exactly the same for the ABS to not malfunction or have any problems? What is an acceptable staggered wheel combo with a 245/45/17 front. I want a wide rear rim and hopefully 305 or so rear tire. Is this just not recommended?
Old Jan 19, 2011 | 04:04 PM
schmallz's Avatar
schmallz
Differnet tire sizes won't be the end of the world. Jazzer says you shouldn't go more than an inch difference in diameter.
I run 255/40R18(about 22.2") and 285/40R18(about 23.2") and have no problems.
Old Jan 19, 2011 | 10:07 PM
Andy13186's Avatar
Andy13186
whats the widest 18 inch rim/tire combo that would fit on a 2003 gt?
Old Jan 20, 2011 | 08:00 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Tire diameter differential is indeed a problem, when it gets to a certain point. I forget the percentage, but is around 1". I woud be willing to bet that if schmalls really gets on the brakes, the ABS will act up sooner than otherwise due to rotational differential in speeds between front/rear.
If the tires are the same diameter, it will make zero difference to the ABS in any way. If you like this look.... GFI
As for what will fit well....? A very common combo is 9"s & 10"s
Jazzer
Old Jan 20, 2011 | 10:46 AM
Soldier GT's Avatar
Soldier GT
Once again Jazzer speaks knowledge....
Old Jan 20, 2011 | 01:29 PM
schmallz's Avatar
schmallz
Jazzer
I don't have these slotted rotors for nothing, I'm on the brakes pretty hard now and then.
Old Jan 20, 2011 | 01:36 PM
schmallz's Avatar
schmallz
I don't have traction control, I might not have ABS either.
Old Jan 20, 2011 | 01:44 PM
schmallz's Avatar
schmallz
I know you can fit an 11" rim in the back with no trouble. 315s are probably your best bet as I have never seen 325s and 335s would be a little big.
Old Jan 20, 2011 | 04:02 PM
Jazzer The Cat
Retired Moderator
Sounds like you may not have ABS. As I understand it, not all New Edge rides came with them or TC. I think if it has one, it will have both and since no TC, probably no ABS either.
Have you peeped my Brakes upgrade thead, mister?
Old Feb 21, 2011 | 06:48 PM
harbre32's Avatar
harbre32
my 2000 gt has abs but no tc
drfister
May 3, 2018 10:38 PM
zachary1988
Sep 1, 2015 07:58 AM
Tyoung68
Aug 25, 2015 04:31 AM
Cobra4me
Carolina Regional Chapter
Aug 19, 2015 05:54 AM
stanngg
Aug 12, 2015 03:43 PM
