footwell lights?
#32
Thanks guys.
tdurham19- Since I think the question was actually for me, I just replaced my maplights with blue LEDs. Under the seat/footwell is a separate kit.
Also btw bluestang I was 17 when I put those in and it was just me and my 20 year old brother. Its not too complicated.
#33
BlackArmor - What are some of the features from the control box for your interior light kit? Also, got a picture of it? Thanks.
#34
First off I want you to be aware that I found the same kit I have for a lot cheaper at http://www.ledunderbody.com/7-Color-...hting-Kit.aspx . That one also has 7 different colors whereas mine is just blue. Shoooot...
The control box has an on/off button, a switch modes button, and a pause button (which I never use). There are 7 modes I believe: 3 different levels of brightness, 3 fading speeds (every 30, 20, 10 seconds or something like that) and one music mode, the lights will strobe to the bass of the music (more bass = faster strobe). It also has a sensitivity dial on the side of the box for the music mode so you can make it just right for any song.
Here is the box (the flash messed up the surface)
Uploaded with ImageShack.us
Here is one LED strip under the drivers footwell
And two under each seat. I used zipties and painters tape to make sure they didn't wiggle around.
Hope that helps
Hope that helps
#35
Hope that helps
Hope that helps
The way I see you hook up your lights, that's going to help me when it comes to installing these leds. Thanks!
#36
whtnblkgt- The middle button cycles through the 7 modes. I don't know much about the 7-color kit, I assume if there was no other way to cycle through the colors then you could just press the pause button when the color you want comes up. I don't think they would sell a kit that wouldn't allow you to choose your own color but you never know.
Also I have 6 LED strips total in my setup so i could get light coverage all the way around the sides and back of my seats.
#37
WhtNBlk.GT
#38
Where does the wire from the tube under the seats go? Im realllyyyy confused at how to wire all this up.. i dont want a bunch of wires laying around. I also want to rig it such that the lights come on when I open the doors..
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
