Anyone know how to remove the power seat and lumbar switches?
Old 07-06-2013, 11:46 AM
Jonjonbear
Jonjonbear's Avatar
Default Anyone know how to remove the power seat and lumbar switches?
Hello all,
In the midst of renovating my 2005 GT and have a set of Katskins on the way. I am wanting to paint the plastic sides on my seats which are currently dove gray but I cannot figure out how to get the switches out. It appears the seat switch **** should pop off but it's not doing so easily. On the lumbar switch I can pop one side loose but can't get the other side loose. Anyone know how to remove these? I don't want to break them.
Thanks,
John
Jonjonbear is offline
Old 07-06-2013, 01:41 PM
WildAzCat
WildAzCat's Avatar
If you can't get them off, maybe you could use painters tape and mask around the switches.
WildAzCat is offline
Old 07-06-2013, 02:59 PM
MustangFirstCar
MustangFirstCar's Avatar
See if this or maybe another section may help http://iihs.net/fsm/?dir=453&viewfil...ck%20Power.pdf
MustangFirstCar is offline
Old 07-07-2013, 03:19 PM
Jonjonbear
Jonjonbear's Avatar
Thanks for the link! describes a bit on the removal but still not sure where the clips are. On the power seat switch just says "remove ****" but doesn't say how. Guess they expect you to be a ford mechanic and know how such parts work! :-)
Old 07-10-2013, 09:07 PM
sdonaghey
sdonaghey's Avatar
The lumbar switch will come out. You just gotta work each side and release the small tabs. Get a small pick tool and pry it out little by little evenly n all side and soon enough it will clear the the bumps and come out.
The seat slider cover will come off. I just tool one of those panel pry tools and slowly put pressure on it and the cover pops off.
I removed mine, cause I was thinking of getting them hydrocarbon dipped, but decided to hold off for now.
sdonaghey is offline
Old 07-22-2013, 11:10 AM
Jonjonbear
Jonjonbear's Avatar
Thanks so much for the tips, worked perfect!
spamedic
09-09-2015 12:15 AM
whatsup62
09-03-2015 01:38 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Anyone know how to remove the power seat and lumbar switches?
