Speedo gear for 06 GT with 3:73 rear
I need some help with this topic. I used the Search, but I could not find the answer.
I am getting ready to have a set of FRP 3:73 gears installed on my 06 GT. What
speedo gear do I need to calibrate my speedo?
RE: Speedo gear for 06 GT with 3:73 rear
As Hammeron and Bluestar stated before our cars dont need a speedo gear anymore, just a computer calibration that can be done easily with any of the programmers available, if you dont have one you can just borrow itor take you car to any Ford dealer.
I don't think you can borrow it. I had to reload my custom tune and change the axle ratio in the parameters.
ORIGINAL: jrm1900
ORIGINAL: moosestang
ORIGINAL: jrm1900
ford dealer cant recalibrate either, without a kit they sell, but your tuner can do it
As per the Ford dealer they reprogrammed the TPS sensors after I changed wheelsand didnt even charge me for that, so I thought gears should be the same. Anyway a tuner will work for sure.
ORIGINAL: GDZILLA95
Correct me if I'm wrong, I believe these cars don't have a mechanical speedometer gear. It's all monitored electronically, correct?
Thanks for all of the replies guys. One question on using my SCT.
Will I have to reset the computer back to the factory settings and then
set the custom tune to calibrate the speedo?
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
