Crap, my speedometer reads too high...
#21
RE: Crap, my speedometer reads too high...
ORIGINAL: jmk3
Sounds like your cars ecmwas set up for 18" wheels. If so they should be able to fix at the dealer.
You can swap OEM 16s for OEM 17s or OEM 18s and not need to change the Revs
Per Mile setting.
#22
ORIGINAL: NELS GT
When I took mine in they just walk around the car with a little remote control device until your car honks then they send you on your way.[8D]
#23
ORIGINAL: 157db
Stock 17 and 18" rims have the same Revs Per Mile as the tires are different sizes.
Per Mile setting.
ORIGINAL: jmk3
Per Mile setting.
#24
I noticed it about a year ago...35-40 mph, my car's speedo was dead on accurate. At 70-80 mph on the speedo, my car's speedo is off by about 5-7mph (I'm going anywhere between 65-75 mph per GPS, but the speedo reads higher).
I figure I'll just fix it when I do the tune. Fire & forget, I guess.
#25
Wow - I thought it was just me. I installed 4.10s a while back, used the XCal2 to reset the rear diff and also put in the rev/mile for good measure. Speedo has been off just like you guys say, in the higher MPH ranges. Someday when I feel like it I'll probably mess around with the settings in the XCal, see if I can get it closer to reality.
#26
Good to know other people are having this problem.
Anyways, here's an update:
Took my car to the dealer today to have em look at it. They said sometimes it doesn't come from the factory with the right calibration and it's probably just a simple software fix.
I didn't have time to leave it with them but if your cars are still under warranty I'd reccomend you do that. Some people might not think it's a big deal but keep in mind that your odometer might be reading off too. This means that there's anywhere between 5-15% extra mileage on your car than there actually is; not something to scoff at for resale value etc. That's my major concern anyways.
#27
I'm having this problem on my '96, but it's intermittent.
I've noticed the same disparity that you guys are talking about between the speedo and the GPS for years, but the other day I was supposedly going 90 in traffic. No way.
Sure enough, the GPS indicated 73. This has happened a few times on the highway, the speedo indicating way too high a speed. In most cases, though, it's shows a nearly accurate value.
The intermittence of the problem makes it a bigger deal, since I have no idea when the thing's right. A 17 MPH difference isn't acceptable. Has anybody seen this situation?
Thanks!
Thanks!
mungodrums
09-28-2015 10:54 PM
09-25-2015 09:06 AM
panic
09-10-2015 05:56 PM
