Sponsored by:
Sponsored by:
How much for lowering springs install?
Old 05-08-2008, 01:51 AM
  #21
actfastus
actfastus's Avatar
Default RE: How much for lowering springs install?
I live in Korea and took to the local Ford dealership. They charged $70 for the front and $90 for the rear even though I thought it would have been reverse since the front takes more work. I just didn't have the time to do it myself. I put in FRPP springs. Plus had realignment done...car is 3 years old. Makes car look a lot better, but stiff ride. Sorry no pics yet. I am sure you could it done for a couple of six packs if you cannot do it yourself.
actfastus is offline
Old 05-08-2008, 02:05 AM
  #22
Orion_240
Orion_240's Avatar
I guess if you have no job and all the tools you need then yes, you could call it free.
If you have a job, the 3 hours it takes will be whatever your hourly income is times 3.
Add the cost of a floor jack, jack stands, rental for the spring compressors, and any other tools you don't have.
Doesn't sound free anymore does it?
Plus your own work won't be warranteed!
Maybe instead of misguided "it's free" advice you could offer to help someone on a job! Maybe make some money!
Orion_240 is offline
Old 05-08-2008, 02:41 AM
  #23
AK_Kayaker
AK_Kayaker's Avatar
Unless you are taking three hours off from work, then you should not count your wage.
I never include the price of general tools, that I could use for many different projects.
So that leaves us with the spring compressor, I'm figuring about 10 to 15 to rent for day.
Not free but darn close, and I for one do it cause I like it, and if I had to pay for install on all parts,
I could not afford as many, as labor is not cheap.
AK_Kayaker is offline
Old 05-08-2008, 11:07 AM
  #24
Dex
Dex's Avatar
If you buy those things then you can do more of your car work in the future.
Im annoyed by all the pansies in here. Unless youre building an engine I think you should figure it out and do it yourself. Be a man and stop taking your car to a dealership and getting screwed like our women do. Do it on a day off and have fun figuring out how to do it yourself.
Dex is offline
Old 05-08-2008, 11:30 AM
  #25
richmod
richmod's Avatar
Do you have to remove the rear tires to remove install the rears? Also, what jacking point do you use in the rear? You guys jacking from the diff or somewhere else?
richmod is offline
Old 05-08-2008, 11:46 AM
  #26
DarkFireGT
DarkFireGT's Avatar
ORIGINAL: AK_Kayaker
I "rented" the spring compressors from Autozone. They basically sold them to me and returned them for full price when I was done. I guess that's how they do it here. So it didn't cost me anything to rent them.
Three hours of my time at my job is $81. I wouldn't be able to find a shop to do the front and rears for under $100.
DarkFireGT is offline
Old 05-08-2008, 12:14 PM
  #27
grampa_stang
grampa_stang's Avatar
You don't even need a spring compressor to do the fronts. Get the car high enough
and support the lower control arm (where the bottom of the shock mounts) with a
floor jack. Take off the the big nut that holds the shock to the upper mount and leave
the 4 small nuts alone. Then slowly lower the jack to release the spring tension.I saw
it done on horsepower tv when they did the GT to Roush conversion. I watched it numerous
times and it looks simple.
grampa_stang is offline
Old 05-08-2008, 12:51 PM
  #28
jawsgt
jawsgt's Avatar
yes i know wut ur talking about and after taking it apart i figured it out. if i had to do it over again thats the way ide do it. never watched theepisode but i can c how its easy
jawsgt is offline
Old 05-08-2008, 12:58 PM
  #29
bcstang
bcstang's Avatar
yea but you guys probably all have driveways....i have a two car garage with 2 cars in it, and no driveway. but no worries, when i do lower my car i will find a family member with a driveway!!!
bcstang is offline
Granatelli Sales
01-20-2020 12:34 AM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: How much for lowering springs install?
