MSD Launch Master Installed. Pics, Vids, Write-up, etc...
RE: MSD Launch Master Installed. Pics, Vids, Write-up, etc...
I really want one of these because they are cool but the class I run in doesn't allow any electronics. Even if I move up a class they still don't allow electronics. If I want to run this I'd have to move up to the Super-Pro class. Trying to runmy manualtranny against delay box cars would be racing suicide.
Nice write up DarkFireGT.
Guys, this works great for me, however, at least one person has stated it's holding RPM a bit lower than what he set it too. MSD is looking into it, could just be that particular module.
I installed it last week and like I said, it's working great. Problem now is traction. Even at 2300rpm I can't get any traction, so I'll be looking for DRs real soon. I have Nitto 555s right now. I'll be going to the track the weekend of 19 Jul where I run ET Streets, so we'll see how well it does.
Easy install and great mod for the track.
ORIGINAL: blueherd02gt
If I werent blown I'd be all over that... When I put the accel COP's on it took an hour and a half...Damn 2007's[:@]
ORIGINAL: scramblr
ORIGINAL: scramblr
Not sure what you mean by this. Are the connectors for the accel COPs different than stock? If not, it just plugs right in.
ORIGINAL: DarkFireGT
Yes, but you have to disable a switch on the clutch that turns off cruise when the clutch is depressed. It also limits the revs by pulling fuel, which is definitely not safe, especially if you're running any forced induction.
No, if you read the notes in the write-up, I purchased it. You can use the clutch position switch built into the car, but I didn't want to tap into the existing wiring, just in case I ever get rid of the car. And obviously autos don't have that.
I'm going to be trying to find some kind of adhesive that will work with metal & plastic and not eat the plastic so I can get rid of the electrical tape. But it's working fine for now.
ORIGINAL: rford426
can we not get a 2step in our tune with a sct programmer?
ORIGINAL: rojizostang
did the underdash switches come with the unit?
I'm FI and it works fine...has nothing to do with FI or NA. The problem with using the rev limit in the SCT is that it cuts fuel not spark (that's my understanding). While NA that would probably be OK, but while FI, cutting fuel is not necessarily a good thing.
Again, I personally wouldn't use the built in one. It's never good to run lean, especially considering you're going to be pushing the car when doing so. For just over $200, I'll take the piece of mind that comes with running the MSD unit instead. Pulling fuel during high RPMs is not safe.
But, if you want to use the one built into the SCT, you'll need to disable the sensor for the clutch that turns the cruise off when the clutch pedal is depressed. Then have your tuner enable the 2Step in your tune.
Thanks,
breaking
10-02-2015 01:27 PM
