Sponsored by:
Sponsored by:
installed AVIC F700BT last night!! Pics inside!!
Old 03-12-2009, 09:45 PM
  #61
One Bad Stang
One Bad Stang's Avatar
Originally Posted by xxdmxx
Anyone know where to tap for the reverse and VSS? I read that to tap into the VSS you need to go into the engine compartment, but isn't there a VSS source where the stock head unit was?
reverse goes to the 12v wire on the back up plug on the tail lamps (stick shift cars) and vss i think goes to a blue wire off the pcm under the hood. look at the avic d3 how to, it's in there.
One Bad Stang is offline
Old 03-12-2009, 09:53 PM
  #62
xxdmxx
xxdmxx's Avatar
Do you happen to know where the reverse is on an Automatic by any chance?
xxdmxx is offline
Old 03-12-2009, 11:05 PM
  #63
One Bad Stang
i dont, but you can probably find it somewhere arround the shifter.
Old 03-12-2009, 11:45 PM
  #64
rford426
rford426's Avatar
I wired mine the way you say minus the vss wire...how do i get the camera to come on my pushing the rear view on the a/v source menu? so i could watch it as i drive as well
rford426 is offline
Old 03-13-2009, 01:22 AM
  #65
One Bad Stang
that i do not know. i dont have a back up camera.
Old 03-13-2009, 08:28 AM
  #66
rford426
rford426's Avatar
hmm i had it wired like that in my last car but i did not do the install so i have no idea how they hooked it up...any one hsve any suggestions?
rford426 is offline
Old 04-15-2009, 03:19 PM
  #67
gidyup
gidyup's Avatar
Default AVIC-F700BT + my splash screen
I had the AVIC-F700BT installed about a month ago and really like it. I didn't plan on watching DVDs in the car so this model has everything I needed, although you could play DVDs with an external player using the A/V input.
Nav works great. If you turn the master volume down to soften the beep sounds, the directions voice gets a little too faint so I do have to put up with a slightly louder beep than I'd like.
Sound is much better than the Shaker1000; I upgraded my amps too which also helped.
Voice recognition is inconsistent but I don't use it and probably wouldn't even if it worked perfect.
Hands-free Bluetooth for the phone is awesome. I love having my contacts downloaded to the unit. I can keep my phone in my pocket and it synchs right up.
It does take some time for the unit to boot-up completely but the music kicks in right away so it isn't that big of a deal to wait for the rest of the stuff.
I created my splash screen in photoshop using the new 2010 'stang badge. My install looks exactly like the original poster so I won't bother with photos except that the microphone is next to the overhead center console.
Cheers!
Attached Thumbnails installed AVIC F700BT last night!! Pics inside!!-2010_ford_mustang_badge_likes_to_run_2.jpg
gidyup is offline
Granatelli Sales
01-20-2020 12:34 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: installed AVIC F700BT last night!! Pics inside!!
