Sponsored by:
Sponsored by:
HDL question New install
Old 03-09-2009, 05:52 PM
cobra0478
cobra0478's Avatar
Default HDL question New install
I installed the Retro solution biox (dual beam)light kit in my car yesterday.
Last nite I went out for a drive.
On low beam all is well,I decide to check them out on high beam.If I hit a bump in the road the lights bounce.
I checked this evening after work to make sure that all connections were tight and that the light fixtures were seated and locked in properly,all appears fine.
If I grasp the lock devise I can move the bulb to simulate the problem I have driving,they also shake or bounce on closing the hood.
I do not notice the problem with low beam.
Is there a solution?
Did I do something wrong?
I did use the red washer from the stock lights along with the one in the kit.
I am open for suggestions.
Anyone have any ideas???
Thanks for looking,
Don
cobra0478 is offline
Old 03-09-2009, 06:49 PM
dschmink
dschmink's Avatar
Hm.. when I put mine in I don't think that I used the stock washer. I just took out the stock bulbs and put the new ones in
dschmink is offline
Old 03-10-2009, 11:13 PM
adidasUNT8
adidasUNT8's Avatar
I installed them on mine a few months ago....you need to take off the old washers on your old lights and double stack them......otherwise they will sit in pretty loose and will rattle around a little bit....just make sure you get the washers lined up properly before you lock them in
adidasUNT8 is offline
drfister
05-03-2018 10:38 PM
GimpyHSHS
08-29-2015 06:30 PM
toastintx64
08-29-2015 05:12 PM
Shifty Magoo
08-25-2015 03:08 PM
Quick Reply: HDL question New install
