Sponsored by:
Sponsored by:
can u switch the hood joints to the front?
Old 05-16-2009, 04:09 PM
Red Beast
Red Beast's Avatar
Default can u switch the hood joints to the front?
hey guys,
i was curious if somehow it is possible to switch my hood joints from the rear and put struts in the front so the hood opens the opposite way like a viper, i just thought that not only would it be unique and cool, but i thought itd b alot more secure to if the main holdown points are in the front
Red Beast is offline
Old 05-16-2009, 04:21 PM
157dB
Cut & Paste Expert
157dB's Avatar
Anything is possabe.
Is it easily doable, no.
But if you can dream it, you can make it a reality.
Take it to the local customizing shop and throw some $$ at them.
Get the lambo doors at the same time so they all swing the same
way when opened. Maybe they can switch around the doors to
make them suicide doors?
Seriously, get'er done and post pics....
157dB is offline
Old 05-16-2009, 04:24 PM
suoperdave84
suoperdave84's Avatar
I would have to check out the underside of a hood, but there has to be a place there stiff enough to bolt to. You also have to have something fabricated to hinge from, and the hinges might not operate optimally with the angles, position, etc.
You can certainly do it.....depends on your skills or how much money you have to pay for someone else's skills.
Also, keep in mind how hard it will be to work on your car that way. The stuff at the back will be easier to reach, but everything up front will be harder.
suoperdave84 is offline
Old 05-16-2009, 04:31 PM
Red Beast
Red Beast's Avatar
well i thought even if its not stong enough in the front for just an underside attachment i could have them drill all the way through and have the bolts look like hood pins or something to
Old 05-16-2009, 04:52 PM
Lethaldosage423
Lethaldosage423's Avatar
like they said anything is possible but you would have to think about the winsheild washers and probably relocate them
i would just be worried about the alignment of the hood.
Lethaldosage423 is offline
Old 05-18-2009, 01:16 PM
d_ames117
d_ames117's Avatar
I love that the hood on my 92 Saab 900T hinges at the front!
d_ames117 is offline
2007CalSpec
12-13-2020 11:42 AM
StalkerGT
09-25-2015 02:41 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: can u switch the hood joints to the front?
