NEW LED CHASE TAILLIGHTS
The first LED taillight kit with CHASE action. No wire cutting and no harness change out. No permanent modifications to your Mustang at all. Just pop in the LED's in place of your incandescent bulbs and go! LED's virtually last forever, are redder and produce a clearer light than incandescent bulbs. All three sections of the taillight light up during braking and turn signaling. Taillights sequence once during braking and continuously during turn signal. Included in your kit are six CHASE LED bulbs, connectors, and complete instructions
There is a write up on installation in one of the mustang mags this month.
They also come standard without the chase but you have to
order them one way or the other. But they fit into OEM taillight housings
and have the proper load resistors included for normal flash rate.
You loose the burned out bulb feature but with the 50,000 hour MTBF rate,
they will outlive even the youngest Mustang owner....
The cost is kinda high but the coolness factor is right up there also...
I will be staying with my CDC Dynamite Sticks until they need to be repalced
from not working....
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
