Question regarding stainless steel brake lines
I recently scored a good deal on a set of the GT500 calipers, rotors and pads. I want to upgrade my brake lines to stainless steel ones since I'll have to bleed all the fluid anyway.
Tirerack.com has goodridge stainless lines for $165, it says Mustang 05-09. Can I just buy these and use these with the GT500 front calipers?
http://www.tirerack.com/brakes/brake...upe&perfCode=S
When I got my GT500 takeoffs I went with Moss motors GT500 DBA rotor, pads, and brake line kit. I am not sure if the brake lines are compatable, but you could check on their part #s and see. I think the brake lines are the same though.
However Steeda sells stainless steel lines that work on both vehicles?
Keep the answers coming
The Steeda lines are pricey, but they come with factory-fit brackets that make the swap very convenient. They also come with banjo bolts... not sure if the others do.
Speaking of banjo bolts, do NOT overtorque those things. 30 ft-lbs only, I believe. They crack really easily, and that's really the last thing you want cracking on your car.
Hy, yes they fit perfectly. There a direct replacement. I got them on my car and, yes, the tire rack has the best price. That's where I go mine. Good luck.
P.S. The braking is amazing the first few times you'll try it. It's like night and day.
The question that comes to mind is do you have rims that will clear the GT500 calipers?
I'm building some kind of hybrid, GT, GT/CS, Shelby GT, GT500
Now if you get a big brake kit (6 or 8 piston calipers) then that's a different story but your paying about 2-3K brand new easy....just for the fronts
musnicki
09-23-2015 07:11 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
