Sponsored by:
Sponsored by:
My tremec Magnum XL from American Powertrain
Old 11-14-2013, 01:19 PM
  #21
slickman
slickman's Avatar
Cool, I have not driven it much. Only put about 50 miles on it, been busy doing other work on the car. All new pulleys, new tensioned, new water pump, new alternator, new Serpentine belt, new ATI dampener and new Pypes mufflers. I have one more thing to do and I'm done, custom motor mount bracket. The OEM bracket is hitting the header on the driver side and its causing a vibration. Took weeks to figure that out and allot of un-needed work. Live and learn..
slickman is offline
Old 11-14-2013, 03:22 PM
  #22
Andy13186
Andy13186's Avatar
good job finding the issue though, and nice build overall
Andy13186 is offline
Old 11-14-2013, 07:57 PM
  #23
slickman
slickman's Avatar
I have the wood jig all made and a stock oem bracket mounted. Im waiting for the 1/4 inch steel plates to get here i ordered. Then i can start welding.
slickman is offline
Old 12-18-2013, 03:38 PM
  #24
yourmyboybh1026
yourmyboybh1026's Avatar
So, I didn't want to start a new thread so I'm resurrecting an old one. I'm considering this transmission, but I'm wondering if I can use the aluminum drive shaft I have now, or will I need a new one? If I need a new one, how long, and where should I get it.
yourmyboybh1026 is offline
Old 12-18-2013, 04:28 PM
  #25
slickman
slickman's Avatar
You can use the driveshaft to have but you're going to have to have it cut down and rebalanced because the tremec T 56 is longer than the stocks one you have in there now presuming you have a 3650
slickman is offline
Old 12-18-2013, 04:41 PM
  #26
slickman
slickman's Avatar
Oh and you'll need to have universal joints put on the transmission end of the driveshaft because its different than 3650. You also need a tail shaft yoke.
slickman is offline
Old 12-18-2013, 05:05 PM
  #27
yourmyboybh1026
Ok, cool, thanks for the info
baddog671
07-26-2016 01:20 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: My tremec Magnum XL from American Powertrain
