Sponsored by:
Sponsored by:
High pitched whistle at 2000 rpm
Old 08-20-2014, 06:43 PM
kevsgt
kevsgt's Avatar
Default High pitched whistle at 2000 rpm
Hello! I've discovered a strange noise. When my driver's side window is down, I can hear a very high pitched whistle or squealing just around 2000 rpm. It's easy to confuse with the sound of other car's brakes squeaking, but I confirmed that is not what I am hearing. Could this be related to my cold air intake? I installed an aftermarket intake and throttle body about a year ago.
kevsgt is offline
Old 08-21-2014, 02:17 AM
drewsky
drewsky's Avatar
Have to be a little more specific about the speed of the car when it's going it. Also what gear, grinding, ect. Could be anything from reading the post.. And that doesn't help
drewsky is offline
Old 08-21-2014, 03:00 PM
kevsgt
kevsgt's Avatar
The noise is in the 1500-2000 rpm range when I am traveling at highway speeds, 50-60 mph, and only when I am pressing the gas pedal. 2nd or 3rd gear. I have a 2006 GT, automatic. 90k miles.
kevsgt is offline
Old 08-21-2014, 04:50 PM
dslpow3r
dslpow3r's Avatar
Is it the windshield? I had an f250 that had an high pitch noise coming from outside while traveling at certain highway speeds. Took it to the dealer and they found it coming from the windshield. i was missing some adhesive/weather stripping that when the wind would hit it at a certain speed would make a whistling noise.
dslpow3r is offline
Old 08-21-2014, 05:43 PM
Nuke
Nuke's Avatar
If it comes and goes with being on the accelerator, then you've narrowed it down to drive train, intake and accessories.
Nuke is offline
Old 08-22-2014, 05:42 AM
Bronson006
Bronson006's Avatar
A fuel injector not seated properly..Had an issue similar on an old 1980 Porsche 911SC..Once in place properly..Whistle stopped..Hope this helps...
Bronson006 is offline
Old 08-26-2014, 05:29 PM
kevsgt
kevsgt's Avatar
I've never messed with fuel injectors. Is this simple to get it seated properly? I guess I still need to browse the boards to look into this procedure.
What possible repercussions would result if I let it go to long?
kevsgt is offline
Old 08-26-2014, 05:31 PM
kevsgt
kevsgt's Avatar
Thanks. If it is the intake, any ideas where? I tried tightening the hose clamp that holds the filter on, as well as the hose clamp that attaches to the throttle body. No change in whistle. Could there be a hole somewhere that could cause this?
kevsgt is offline
Old 08-26-2014, 05:43 PM
13'GT Black
13'GT Black's Avatar
lets hold hands and pray its not the trans.
13'GT Black is offline
Old 08-27-2014, 01:59 AM
Bronson006
Bronson006's Avatar
You should notice hesistation in motor if its really bad..Just ensure the injectors are seated firmly in place. I checked a few other sites that claimed they can be knocked loose easly..And do whistle if there loose...Also check the vaccum lines, another whistle maker in the engine bay...Hopefully something easy as this is your culprit....
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
Sixer4Life
10-12-2015 04:26 AM
Drastang
09-30-2015 03:48 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: High pitched whistle at 2000 rpm
