Sponsored by:
Sponsored by:
New Rear Axle and Poly Bushings Install
Old 10-02-2014, 10:00 AM
  #21
GS81VETT
GS81VETT's Avatar
Originally Posted by gmoran1469
I think I had mine on a lift when I did it. Didn't add any friction mod iirc.
Ford recommended 75/140 - 2 quarts and on bottle of the Ford Friction Modifier. I just put the modifier in one of the quarts and then put it in the diff housing.
Man she is quite!! Almost to the point I think something is wrong. I did not realize just how load it was with the bearings going bad..
icon_dance-twist:
GS81VETT is offline
Old 10-02-2014, 11:21 AM
  #22
gmoran1469
gmoran1469's Avatar
icon_dance-twist:
i may need to add mod when i swap to my 4:10s then. My rear has a bad whine when on the highway.
gmoran1469 is offline
Old 10-02-2014, 12:42 PM
  #23
Norm Peterson
Norm Peterson's Avatar
I think the friction modifier is mostly to reduce/eliminate limited slip clutch chatter, not whine. Whine is a setup or wear issue.
Norm
Norm Peterson is offline
Old 10-02-2014, 03:11 PM
  #24
ghunt
ghunt's Avatar
Originally Posted by 2cokeman
Quite a bit of rust under there!
Other than the tailpipes...not seeing it. Looks better than mine
ghunt is offline
Old 10-02-2014, 03:43 PM
  #25
gmoran1469
gmoran1469's Avatar
Norm
It's a stock rear end, haven't swapped any gears, yet. All I did was swap fluids to RP synthetic.
Old 10-09-2014, 09:13 PM
  #26
UPRSharad
Former Sponsor
UPRSharad's Avatar
Upgraded control arms improve stability, but certainly don't seem to be necessary for this car. That rear end becomes sketchy in the 10-second zone. You should be fine for a while.
UPRSharad is offline
Old 10-10-2014, 08:06 AM
  #27
GS81VETT
GS81VETT's Avatar
Cool
So after driving the car for a bit with the new rear end I can report she is very quiet! BUT I did not reprogram the PCM yet with the new gear ratio. The issue is/was the car had a tune on it and when I tried to use my Diablo Trinity the device saw a custom tune and would not over right it. It needs the stock to backup. So I have been driving her for a bit on this tune......HMMMM she does not like that! The transmission is NOT happy. She gets confused in third and slips up to 6K RPM and then slams into 4th...and that is NOT putting my foot into it just driving.
So I took the PCM out and sent it to Diablo Sport. They flashed it and overnighted it back to me at NO COST!! What a great company!! I will put in the new PCM today and then put a tune on it with the new gears and we shall see. I’ll keep you updated.
GS81VETT is offline
Old 10-10-2014, 08:32 AM
  #28
Norm Peterson
Great service. Keep us posted.
Out of curiosity, what was your car's axle ratio before the 3.73's went in?
Norm
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
prophotog
08-26-2015 11:55 AM
JonnyBlazeGT
08-09-2015 10:19 AM
Quick Reply: New Rear Axle and Poly Bushings Install
