Sponsored by:
Sponsored by:
mustang 2007 tick/knock noise
Old 12-17-2014, 02:47 PM
Chrisdico
Chrisdico's Avatar
Default mustang 2007 tick/knock noise
I have a horrible noise coming from my car and any help would be appreciated from fellow ford drivers. Checked my intake by spraying some carb cleaner and noticed no change. I also pulled the plugs and injectors one by one to tell if noise altered and the engine just sputters every time I pull one so I have ruled out injectors and spark plugs..Thanks Here is the video I made
Check out this video on YouTube:
https://www.youtube.com/watch?v=D0GsdR0q6FM
Chrisdico is offline
Old 12-17-2014, 02:59 PM
waykooljr
waykooljr's Avatar
Cam Follower maybe, this one is out of an 05 GT...
waykooljr is offline
Old 12-17-2014, 03:14 PM
Chrisdico
Chrisdico's Avatar
Thanks I'll take that into consideration. Car only has 95k on it and got and oil change every 3000 miles.
Old 12-17-2014, 03:25 PM
waykooljr
waykooljr's Avatar
Yea, I'm just guessing. It sounds like it's coming from the valve train but it's hard to tell with knocks and ticks sometimes.
I had a 'Vette that took to knocking and I thought the worst, wound up being the nuts or bolts on the flywheel backed off and were tapping on the block.
Good Luck!
Old 12-17-2014, 03:30 PM
waykooljr
waykooljr's Avatar
If you have a screwdriver long enough, you can try poking around at different places and put your ear to the handle to kind of pin point where the sound is coming from, kind of like a stethoscope.
Old 12-17-2014, 03:36 PM
Chrisdico
Chrisdico's Avatar
I bought at stehascope today and was playing around with it..it's so hard to tell where it's coming from.Im tempted to take the valve cover and get a look.
Old 12-21-2014, 10:22 AM
Chrisdico
Chrisdico's Avatar
Thanks you were right I just had to replace a rocker arm.cost me 12$ and car is running great
91StangOwner
08-20-2015 11:34 PM
gagemcc
08-17-2015 10:30 AM
92 5.0stang
08-13-2015 06:46 AM
daytooday
08-11-2015 09:22 AM
Daleford
08-10-2015 08:30 PM
Quick Reply: mustang 2007 tick/knock noise
