Sponsored by:
Sponsored by:
Do You Under Coat Your Mustang?
Old 03-23-2016, 01:49 PM
CDC4.0
CDC4.0's Avatar
Default Do You Under Coat Your Mustang?
I'm debating whether or not to under coat my mustang this season.
It's a 2006 and has typical surface rust for a ten year old car. Underbody is in great shape otherwise.
I have been toying with the idea of spraying the sub frame and frame rails with some rust paint as well as possibly getting it oil sprayed.
Any recommendations on brands / strategies?
I'm up in Canada, the land of salted roads, but the car isn't winter driven. It will see rain and wet roads in the summer though, its a DD not a garage queen but I still want to protect it the best I can.
CDC4.0 is offline
Old 03-23-2016, 04:19 PM
Goldenpony
Goldenpony's Avatar
Everything I see recommends NOT to undercoat your car.
Goldenpony is offline
Old 03-23-2016, 09:42 PM
proeagles
proeagles's Avatar
The bodies are dipped in a solution to protect the car from rust when they are painted. There shouldn't be any rust on the body. The differential on the other hand comes rusted from the factory!
proeagles is offline
Old 03-24-2016, 08:43 AM
cavediver
cavediver's Avatar
Never! Undercoating will trap moisture and cause more coorosion, not less. New vehicles don't require undercoating. All those undercoating companies that used to be around like Zeibart and such are long gone thanks to better paints and primers. Just keep the underside rinsed clean and you will be far better off.
cavediver is offline
Old 03-24-2016, 09:00 AM
P51C
P51C's Avatar
You are from Ontario, the land of salted roads. 5 year old cars there look like 25 year old cars out here on the left coast.
That said, you don't drive it in the winter so, the advice you've been given is fine. Undercoating is really chip guard more than rust protection. It just adds weight and makes a big mess for working on the car.
The steel in modern cars is galvanized and/or dipped before priming and painting. Cars just don't rust anymore, unless those coatings are penetrated.
P51C is offline
Old 03-24-2016, 03:32 PM
CDC4.0
CDC4.0's Avatar
So even if the under side is displaying surface rust stay away from underbody rust sprays...I mean hey I don't mind saving the money lol
Thanks everyone
CDC4.0 is offline
Old 03-26-2016, 06:37 PM
07 Stang
07 Stang's Avatar
That surface rust helps protect from salt and other contaminants.
07 Stang is offline
Old 05-10-2016, 07:56 PM
roadpilot
roadpilot's Avatar
'Grace' is stored from OCT to APR, so ... no salt for her!
roadpilot is offline
Mustangjenny904
07-15-2016 12:16 PM
mdj89
02-23-2016 08:31 AM
Mustang_Newbie
02-07-2016 08:08 PM
studerman1
01-26-2016 12:10 PM
jeffhuneycutt
01-15-2016 12:26 PM
Quick Reply: Do You Under Coat Your Mustang?
