3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Need help - transmission not shifting 1-2 at WOT
Old 08-30-2016, 11:10 PM
frostybosty
frostybosty's Avatar
Default Need help - transmission not shifting 1-2 at WOT
So I have a 2015, when I floor it in first gear in normal drive mode not in sport and I floor it from a stopped position, it gets to the top of the rev in first it will rev out and stall really bad. But when I am in sport mode and floor it from 0 it has no problems shifting from first to second. I know this cant be good but cant figure out what is causing it or what is wrong. please help.
frostybosty is offline
Old 08-31-2016, 04:57 AM
David Young
David Young's Avatar
I would take it to your Ford dealer and have them check it. Come back and let us know what they say
David Young is offline
Old 08-31-2016, 06:52 AM
Moderator
JimC's Avatar
I added something to your thread title. Not going to get a lot of looks with just "need help" as the title.
And yes, you are under warranty. Take it to the dealer and let them diagnose what is going on.
JimC is offline
Old 08-31-2016, 07:56 AM
99GTvert
is my username.
99GTvert's Avatar
Interesting so basically it does not engage second gear when accelerating from a stand still in normal mode? Does it make a difference if the car is at a slow roll?
99GTvert is offline
Old 09-01-2016, 02:18 AM
frostybosty
Nope no difference. no matter what flooring it in first it then revs up to the highest (6-7) and then just dies. I have never tried to keep pushing through the rev. I always let off as soon as it dies because i am scared something bad will happen if i continue to give it gas.
Old 09-01-2016, 02:19 AM
frostybosty
Thank you.
Old 09-04-2016, 08:59 AM
rls82959
rls82959's Avatar
Kinda sounds like it's hitting the rev limiter but if that were the case it
would only shut down for a couple seconds allowing the rpm's to drop.
If you have a tune on it, you could try lowering your 1-2 wot shift mph.
Factory tune then let dealer check it out.
Good luck.
rls82959 is offline
Old 09-04-2016, 05:51 PM
99GTvert
is my username.
99GTvert's Avatar
Could this just be spinning the tires, and then the "stalling" being the traction control system stepping in to help control the wheelspin? I mean im not sure why it would take that long for TCS to kick in though, my guess is TCS is almost instantaneous unless the new cars are just different in that they allow more shenanigans before stepping in.
99GTvert is offline
saintsokwitit@yahoo.com
03-14-2022 04:42 AM
99gt_echo
04-03-2016 01:35 AM
grippn
03-16-2016 02:09 PM
dawson1112
03-08-2016 04:08 PM
Taylor D
03-06-2016 08:16 PM
Quick Reply: Need help - transmission not shifting 1-2 at WOT
