Sub cuts out with JVC KWXR-610
Old 08-24-2010, 11:02 PM
RLowIndy
RLowIndy's Avatar
Default Sub cuts out with JVC KWXR-610
I installed the JVC KWXR-610, and used the PAC harness to do so, after hearing that many folks successfully did the same. It sounds great EXCEPT the bass cuts out above volume 19 or 20. Not all the time, but enough to be annoying. I took it to the local "high end" audio place in Indianapolis, and they basically tried to sell me new amps and speakers. I figured I would ask if anyone else has had the same problem and see if anyone has a fix.
I apologize if this has been covered beore, but I found no previous thread on the topic.
RLowIndy is offline
Old 08-25-2010, 12:40 AM
RLowIndy
RLowIndy's Avatar
Oops, juat saw that there is an audio section on this forum, sorry for posting this in the wrong folder!
RLowIndy is offline
Old 08-25-2010, 09:37 AM
2005Redfire6
2005Redfire6's Avatar
Nobody really goes to the audio section... Do you have an adequate amp to accomodate the higher power going out to the sub at higher volumes?
2005Redfire6 is offline
Old 08-25-2010, 09:42 AM
xoxomattyo
xoxomattyo's Avatar
To me that sounds like the amp is powerful enough.
xoxomattyo is offline
Old 08-25-2010, 09:06 PM
RLowIndy
RLowIndy's Avatar
Sorry, I should have mentioned that this car is an 05 V6 Vert, and had the Shaker 1000 head unit in it and the factory sub and amp. The only thing I did was to replace the head unit with the PAC harness. I'm not sure that I answered your question... I guess I don't know
RLowIndy is offline
jwog666
12-27-2021 08:09 PM
piotrek53
10-13-2015 06:54 PM
jrrhd73must
10-02-2015 09:17 PM
mdg
10-01-2015 07:04 AM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Quick Reply: Sub cuts out with JVC KWXR-610
