Weird Sound in the right wheel? Help
Old 03-03-2004, 01:13 PM
deardeeks
deardeeks's Avatar
Default Weird Sound in the right wheel? Help
Whenever I start moving my 96GT it makes a dug-dug-dug-dug-dug sound in the right wheel...... it goes on till the auto transmission shifts to the 3rd (after which i cant hear it). ANy idea what could eb the problem? Dont wanna be kille dby one of these mechanics.
deardeeks is offline
Old 03-03-2004, 07:14 PM
SilverGTV8
SilverGTV8's Avatar
Default RE: Weird Sound in the right wheel? Help
front or rear tire? Did you have any brake work done? It might be a heat shield rubbing.
SilverGTV8 is offline
Old 03-04-2004, 09:30 AM
deardeeks
deardeeks's Avatar
it is the front right-tire...... it just makes a doug-doug-doug sound during the initial acceleration. i saw if soemthing wa sin the way, but wasnt the case. i just had Pepboys check my engine, transmission and other stuff checked before buying the car. After that it has been sounding weird. I am not saying that they did it, but then who knows.......any suggestions?
Old 03-04-2004, 09:44 AM
Chopper
Chopper's Avatar
Is the sound a metalic scraping sound ?Does it speed up with the car ?Is it a light sound ,like sheet metal,or heavy,like frame or rim metal?This can tell you where to look for any evidence of rubbing(metal to metal)or chafing(rubber to metal).Look for misrouted brake lines or possibly a bent rim that changed position during the inspection .All of these are shots in the dark but hope they help.
Chopper is offline
Old 03-04-2004, 11:03 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
Check your lug nuts, one is probably loose.
jeep45238 is offline
Old 03-04-2004, 03:45 PM
deardeeks
deardeeks's Avatar
Firstly thanks for your comments.
It is as if rubber against metal.....it is as if a rubber hits the side, and everytime the wheel takes a rotation it hits it again...... its like pulling a rod up a staircase.... everytime it hits a new step makes a noise... i dont know if i am makign sense.
i tried to look at the tire but there is nothign touching it.... so maybe something within?
Old 03-04-2004, 04:59 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
God damnit.....at least ****in check the free possible fix.....YOUR DAMNED LUGS!!!!
Old 03-04-2004, 05:15 PM
deardeeks
deardeeks's Avatar
Listen I requested you for help.. you do not have to do that... but if you do decide, i suggest you be polite...... people come to this forum for help and information not for your mood swings.
Old 03-05-2004, 10:10 AM
Chopper
Chopper's Avatar
I don't know but is there any way your spindle nut could be loose.Raise the car and try to shake the front tires. If they move find out where they move from and go from there .Yes I thought about lug nuts also but they were to obvious,but it could very well be.Do you feel anything through the steering wheel?You can find some of this stuff through the seat of your pants.Good Luck.
Chopper is offline
Tivo304
08-28-2023 12:19 PM
bjdutch2005
03-24-2017 03:38 AM
2007StangV6
01-28-2016 06:09 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Weird Sound in the right wheel? Help
