swirl questions..
Old 05-10-2006, 12:02 AM
Pietrasz4
Pietrasz4's Avatar
Default swirl questions..
hey guys i have an important question about swirls...to remove them do i need a buffer? now i know with the buffer there is an attachment u can get that is like more abrasive or something...if i bought some swirl remover will that actually remove the swirl or would it just be a quick fix type of thing where it will look good for a while then wear off and the swirls will come back...right now the supplies i have are a claybar, paint cleaner, showcar glaze, and wax, is there anything else i need or what?
Pietrasz4 is offline
Old 05-10-2006, 12:07 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: swirl questions..
You need a buffer. Something like a 2000-4000rpm adjustable buffer will be great for a noobie. Buy some 3m scratch remover/compound and have at it.
Always keep the buffer moving, use in figure 8's just so you never hold it in one place. The paint will look horrid after you wipe the compound off, don't worry - this is normal. Use a glaze/polish and enjoy having much less or no swirl marks.
Dan04COBRA is offline
wbacon
wbacon's Avatar
Need to watch it using buffer that you don't leave burn marks..
wbacon is offline
Old 05-10-2006, 12:20 AM
sprostang
I ♥ Acer
sprostang's Avatar
I would never touch a car with compound or scratch remover. Especially with a dark color. Unless it was just painted and has dirt in the paint. Therefore you dont have a choice. Its way too abrasive. Meguiars makes a swirl remover. Use it with a foam polishing pad with a buffer. Then give the car a good hand wax. It will look good for a while but you may see some swirls again after all of the wax wears away. Check out www.levineautoparts.com They have a great selection on detailing products.
sprostang is offline
Old 05-10-2006, 01:11 AM
2000GT4.6
2000GT4.6's Avatar
Pay someone about 200 bucks to do it. Thats where my car is tonight, at the detailing shop. Well worth it for scratch removal and chip repair from road damage.
2000GT4.6 is offline
tmdm
05-02-2021 02:49 PM
inyadreems
08-21-2015 09:10 AM
05gtrules
04-19-2006 02:02 AM
rasguedo
04-08-2006 11:35 PM
Osk
43
12-16-2005 11:48 PM
Quick Reply: swirl questions..
