big problem, catalytic converter?
Old 06-02-2006, 08:53 PM
mustangdrew
mustangdrew's Avatar
Default big problem, catalytic converter?
Hello-
Hard to describe problem - starts and runs ok (not perfect) for just a few minutes, then when you step on gas rpms drop, engine either goes rough/loses speed or stalls. Will restart, pops when revved, smells kind of like wet paint! This is a '99 GT, 4.6, all stock.
I was thinking the converter or a sensor? Anyone had experience with a problem like this?
Thanks for any help,
Drew
mustangdrew is offline
Old 06-02-2006, 11:09 PM
04BlueGT
04BlueGT's Avatar
Default RE: big problem, catalytic converter?
Sounds like an O2 sensor is bad.
04BlueGT is offline
Old 06-02-2006, 11:41 PM
dlazrael
dlazrael's Avatar
if it was a cat that collapsed, then the car would run, but it would have practically zero accelleration. When my cat collapsed on my old stock midpipe, i was in 1st gear at WOT and only getting 13 mph....
so it sounds like sensor issues, can you run it long enough to get to an autozone to get codes read?
dlazrael is offline
Old 06-02-2006, 11:47 PM
93BlackNotch
93BlackNotch's Avatar
Have you changed your fuel filter recently? You might want to try that... If it's a sensor you should have a check engine light...
93BlackNotch is offline
Old 06-03-2006, 12:31 AM
dlazrael
dlazrael's Avatar
I had a similiar problem when I serviced the CAI on my old v6. I hadnt seated the MAF sensor wire fully and it was causing it to die out under power. Check that too, it might have gotten loose somehow
dlazrael is offline
ShaneB26154
35
03-04-2021 04:05 AM
ohfarrell
10-18-2015 11:27 PM
CarrieS
09-01-2015 01:00 PM
kdryan
08-21-2015 04:01 PM
jjwinel78
08-17-2015 03:34 PM
Quick Reply: big problem, catalytic converter?
