fuel filter, problems
i changed the fuel filter today on my 02 gt at about 47k miles. car was running fine before. i used the inertia switch disconnection method to relieve fuel pressure, took about 10 minutes, but finally all fuel was emptied out of the lines. i was wondering while the car was waiting to die, if this is really the best way to do this as i thought it might be leaning the car out a bit. ive done it before on a 99 explorer with no probs. well i put the new filter in (yes it's installed in the right direction), cycled the key, let the fuel pump kick on and she fired up fine... except for a check engine light. i know noone can really tell me exactly whats wrong with out reading the code, but i wanted to know if anyone had heard of this before. it's running fine, and i tried driving it for a while in case the computer needed to "relearn" anything. im supposed to get my diablosport this week so hopefully i can find out what code is popping. thanks for the help. peace.
RE: fuel filter, problems
sounds kinda weird man, haven't heard of that happening before... there may just be some air bubbles the system has to work out so you may have a minor misfire
also, whenever you do a fuel filter, just pull the fuel pump relay (easy) then do the run/let die method or just crank it a few times.
speaking of which... i have my original filter with 112k... [&:][&:][&:]
i'll do it soon i hope
You don't really have to pull the power and let it run dry. If your car has the access point on the fuel rail you just put a rag around a screwdriver and push it down to relieve the pressure.
Disconnect the battery for about a minute and then put it back on and restart the car. If the check engine light goes away you have nothign to worry about.
ORIGINAL: monkeydude3
musnicki
09-23-2015 07:11 AM
