E-Brake light comes on...
Old 07-10-2006, 10:18 AM
PushinTheLimit
PushinTheLimit's Avatar
Default E-Brake light comes on...
Today coming into work I noticed that my E-Brake light would come on whenever I got on the brakes. It would stay on until I would get back into the throttle and it would go away. But it would keep doing that same pattern each time. I made sure the E-Brake handle was completely down and not engaging it but I don't know what might be wrong....any suggestions??
PushinTheLimit is offline
Old 07-10-2006, 11:29 AM
01BlueCobraVert
01BlueCobraVert's Avatar
Default RE: E-Brake light comes on...
Your brake fluid is low. Check your resevoir (SP).
01BlueCobraVert is offline
Old 07-10-2006, 11:48 AM
shag5150
shag5150's Avatar
Yep......97mustanggt is right.......It happened to me a while back......I just topped off my brake fluid and that took care of it........
shag5150 is offline
Old 07-10-2006, 12:08 PM
PushinTheLimit
Ok.... I'm glad its nothing serious. Thanks guys for the help.
Old 07-10-2006, 01:01 PM
mustang_montana
mustang_montana's Avatar
if its not that, your ebrake position sensor might be loose. mine came off on me before, so the light was constantly on. its an easy fix if that it, just take out the center console and make sure its attached good and tight. its white with a peg on a spring that goes in/out depending on the angle of the ebrake lever.
mustang_montana is offline
Old 07-10-2006, 01:21 PM
monkeydude3
monkeydude3's Avatar
check the fluid. This could be a good indication you need brake pads!
monkeydude3 is offline
Old 07-10-2006, 01:22 PM
Miliock
Miliock's Avatar
Like everyone said...the brake fluid level.
OR in my case it was I needed new pads....give it a look see
Miliock is offline
Old 07-10-2006, 01:23 PM
monkeydude3
ORIGINAL: Miliock
the needing of pads is caused by the caliper piston having to go farter, so fluid comes from the reservoir to fill it up.
i'd reccomend having the brakes flushed when you do the brakes as well
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
Quick Reply: E-Brake light comes on...
