help with prochamber
ok after a couple hours of fighting to get the h-pipe on I start the car up and I have one mean leak comming from the drivers side exhaust manifold where it bolts to the h-pipe. I tried unbolting it and moving it around a bit and that helped but its still quite the leak. has anyone else had this problem? any help would be appreciated. btw '00 GT vert
RE: help with prochamber
Ya I have, when I installed mine on my car, it was perfect. Then I bottomed out on a speed bump & now it leaks on the driver side. I tried to tighten the bolts up but it didn't work. I need to take the thing apart and put it back on.
ORIGINAL: Dan02GT
Yep, you should of saved the stock gasket if you could have. You need to go to Ford and order a new one, they are the only ones who carry it..
04gtmatt
05-13-2005 10:57 AM
