2001 GT idle problem
Hello fellow GT drivers.
Need some help from someone in the know.
My GT suddenly will not idle at all when cold and barely when at normal operating temperature.
The idle RPM's no longer decrease gradually when shifting or pulling to a stop.
It will barely idle when totally warmed up but strugles to maintain 400-500 RPM's.
I realize it is probably a sensor but was hoping someone on the forum may have experienced the same problem and could recommend which one needs replacing.
Thanks,
John
Thanks,
John
RE: 2001 GT idle problem
Sounds similar to last week when my Idle Air Contol went bad... Except mine wouldn't Idle at all unless I gassed it...
If you want to check take off the hose running into the IAC and see if the piston moves when you change from Idle to a throttled Position... If it doesn't then that's probabally it. Some people will tell you to clean it out with brake fluid or carb cleaner also...
I hope that helps ... Good Luck
Rob
Rob
Luke9222
10-22-2015 11:55 PM
cardsrus1
19
09-15-2015 08:37 AM
