starter bolts
RE: starter bolts
The easiest way I have found to do it is. Take passenger front tire off get a couple really long extensions and a swivel snake the extensions through a hole in the k-member that is right in front of that stupid top bolt. You will also want a light but once you shine the light in through the wheel well you should see the top bolt and be able to get the socket on the nut.
RE: starter bolts
ORIGINAL: lizzyfan
After it's done, alot folks just leave it off
ORIGINAL: weasel1088
how the hell do i get to the top bolt of the starter!?![:@]
I have my H-Pipe off and the suspension is at full droop...
RE: starter bolts
ok well i got it off before i came back to read this. i was able to just get a socket with an extension up there and get it off, and i was able to get it back on the same way. so all three bolts are in, i have a new starter, and the car finally starts. thanks guys
logan409
09-26-2015 07:43 PM
