Tire PSI....
Old 05-01-2007, 07:49 PM
Adam03GT
Adam03GT's Avatar
Default Tire PSI....
Im not sure what psi i am supposed to keep my tires at for daily driving... I have 18x9 and 18x10 Chrome DD bullits and here are my tires :
http://www.discounttiredirect.com/di...&tc=MTAHZ9
275/35/18 295/35/18 if that matters..
I heard that you are supposed to keep them at 32 psi but the guys at the tire shop told me to keep it at 40 or so? So what do i keep them at?
Adam03GT is offline
Old 05-01-2007, 08:05 PM
SVTBill
SVTBill's Avatar
Default RE: Tire PSI....
30 for good ride....35 for mpg
SVTBill is offline
Old 05-01-2007, 08:07 PM
Adam03GT
Adam03GT's Avatar
ORIGINAL: SVTBill
O sh*t.... my tires are at 42 right now.... They said something about keeping them above normal psi because the sidewalls are smaller than a regular tire or something? So i should still keep it at 35?
Adam03GT is offline
Old 05-01-2007, 08:18 PM
SVTBill
SVTBill's Avatar
ORIGINAL: Adam03GT
ORIGINAL: SVTBill
i would just do 35 because of better mpg..the ride quality wont be as good as 30 but it will still be better...the sidwall thing is true to a cerntant extent...but you only get "run flat"; what they're talking about if you run your tires @ below 30 or so for an extended period of time
35psi ftw....don't do burnouts though, it will wear the center of your tires out really fast, especially with higher than factory recommended air pressure....centrifugal force > tire
SVTBill is offline
Old 05-01-2007, 08:46 PM
richsw
richsw's Avatar
There should be recommended pressures on the tire itself.
I have stock tire sizes on 9 inch wheels so I keep them at
30 lbs.
richsw is offline
Old 05-01-2007, 08:51 PM
benk87
benk87's Avatar
ORIGINAL: richsw
30 lbs.
Yea not every tire is the same... It should say the lowest you can go and the highest... I would take the two number and go right in the middle... That is what my dumb a$$ does.
benk87 is offline
Old 05-01-2007, 10:48 PM
Chubstang
Chubstang's Avatar
33 in the front 35 in the rear ftw, just don't think for one second with that psi that you'll have any traction.
Chubstang is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Tire PSI....
