head swap ???s
head swap ???s
I was told today that if I wanted to swap out my 2v heads with 4v cobra heads on my 03 GT I would need a new block to go with it?? I dont know if this is true or not because the guy I heard it from isnt the most experienced mechanic, but then again neither am I [&:]. If anyone could give me some answers it would be greatly appreciated.
RE: head swap ???s
You wont need a new block, just all the timing parts, chaings, timing cover.
I think some of the stuff on your SOHC can be re-used.
Basicly compair the engines, check part numbers for everything and start the swap. Work on it slow and go easy.
if you are realy afraid of doing this then I have a solution for you that you might be interested in, if your not interested in buying a block then dont both reading the next part.
I have a 2003 Mach1 shortblock with 0 miles on it for sale. It has all the timing components that you will need along with the cover and dampner and so forth. Its not a forged block but these are good for 650rwhp on blown applications.
I can even include a wiring harness and starter with starter harness. I am getting pictures developed of it right now. You will only need to provide the heads and intake and accessories/brackets.
There are a couple other guys interested in it too right now waiting on the pictures. Basicly who gets me the most money first gets it. Its at $1500 for everything.
RE: head swap ???s
ORIGINAL: na svt
The 4v heads will bolt onto the 2v engine but the compression will be 1 point lower than with 2v heads.
RE: head swap ???s
What I had planned on doing was buying a set of bare heads, and slowly building them up, adding a nice cam, and putting a little extra money into them until i actually have the time to install them on the car.
RE: head swap ???s
You could do all that (headwork, cams, etc etc) and spend a boatload and a half (cams alone are a grand) or just upgrade what you have.
For the same price you could do ALOT with alot less stress and have a faster car...
RE: head swap ???s
ORIGINAL: Twogunsblazin
RE: head swap ???s
ORIGINAL: 2000GT4.6
Matt's 95 Stang
10-05-2015 07:16 AM
