Headlights won't turn on!
Old 01-02-2008, 02:50 PM
wreakhav0c
wreakhav0c's Avatar
Default Headlights won't turn on!
Hi guys. Hoping you can help me out...
When I pull the headlight **** all the way out, only my parking and tail lights turn on. When I put the high beam lever in the "stay on" forward position nothing happens but when I pull it back into the manual position they turn on. Since the beams do turn on, it's not a bulb issue. ShouldI be looking at the fuse or the switch?
Stock 97 Cobra
Thanks
wreakhav0c is offline
Old 01-02-2008, 04:50 PM
99_GT
99_GT's Avatar
Default RE: Headlights won't turn on!
If it's like a 97 GT, I would look at the main light switch. If you have power to the main switch (BLK/ORG) wire, then turn the switch on and check the (YEL/RED) wire comming out.Ifthat wire is hot thenit to the multi function switch, High/Low beamarm. The Flash to Passcircuit is on a seperate fuse.That's whythey work when you pull back on the arm. Let me know if you need more details.
99_GT is offline
Old 01-02-2008, 05:43 PM
deja_voo182
deja_voo182's Avatar
Have you done any mods before this? When I installed my white faced gauges on my 02 the middle grey wire had come out of the connector for the headlight switch cause the same problem you are having. Check the headlight switch and fuses
deja_voo182 is offline
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
Meystang
09-25-2015 04:05 PM
gagemcc
09-22-2015 09:43 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Headlights won't turn on!
