How do you remove the radio?
Old 03-13-2008, 03:32 PM
sliek0722
sliek0722's Avatar
Default How do you remove the radio?
I'm actually trying to remove the center console trim piece with the two AC vents because I need to replace a bulb behind the AC controls. All the guides I've read said you have to start with the radio and it should use radio remover keys but there's no visible slots for anything to slide into
sliek0722 is offline
Old 03-13-2008, 03:49 PM
IIGood
IIGood's Avatar
Default RE: How do you remove the radio?
What year?
If it's the '99-'04, you have to first pop the shifter trim off. Unscrew the shift ****, and then start taking the plastic trim all around the shifter off. It's just held in by a few clips...pull firmly, but not too hard. Then disconnect the connection for the power port...all you have to do is push a little tab down (with a small-bladed screwdriver maybe) and pull the connection out. You should then be able to remove the shifter trim.
Next, remove the trim from around the vents, heater controls, and radio. It's all just clipped in, so grab it and pull firmly...just be careful. Once the clips are free, then remove the connections for the rear defroster, trac control, and fog lights. For those, just push a tab in and pull it off. Start with the traction control one...once that's free, you'll have more slack in the other two.
Once the trim is cleared, then you can take the radio out...it's just held in by two 7 mm screws. Don't know why you'd need to remove that to remove the heater controls, but whatever...they are two separate units...I believe the heater control is also held in by the 7 mm screws. And the whole unit should then just slide out.
IIGood is offline
Old 03-13-2008, 04:13 PM
sliek0722
sliek0722's Avatar
Well if I don't need to remove the radio then I won't. Another guide I read was for 94-99 mustangs and it said you remove the radio first by using two U shape ford keys and after that there are screws and bolts that access the rest of the trim.
I'll try to remove the shifter trim but thats alot of work lol. I don't even have the proper size screw driver to unscrew those screws.
Old 03-13-2008, 04:29 PM
Dilireus
Dilireus's Avatar
I've done it with 4 nails. Just stick them in the holes, and pull the radio out while pushing the nails to the outside. It was pretty easy.
Dilireus is offline
Old 03-13-2008, 04:35 PM
NoRdO
NoRdO's Avatar
I just used a coat hanger.
NoRdO is offline
Old 03-13-2008, 04:43 PM
sliek0722
sliek0722's Avatar
Won't work on the stock radios with CD players found in 2001+. Those don't even have holes to stick anything into.
Old 03-13-2008, 05:37 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
ORIGINAL: sliek0722
shifter trim is held on with clips, not screws...
redass02gt is offline
Old 03-13-2008, 05:39 PM
sliek0722
sliek0722's Avatar
So those 6 little black screw shaped things around the shift boot are clips? Well how do you remove those without breaking them?
Old 03-13-2008, 05:46 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
you don't have to remove the shift boot. just the plastic trim that pops off, and then you just pop off the plastic bezel with the vents.
PM sent.
jwog666
12-27-2021 08:09 PM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Quick Reply: How do you remove the radio?
