Which 2V Intake is worth the money??
#21
RE: Which 2V Intake is worth the money??
ORIGINAL: tbirdscwd
I know everyone is very skeptical to believe anything they read in a magazine, but the trick flow this is the only manifold that they have tested that has seen any gains without ported heads (boosted or not). The trick Flow is also basically a Bullitt manifold on roids which has proven to be ery beneficial especially in boosted applications.
The problem with intakes on these cars is the intake is not the restriction in the flow. The stock intakes and exhaust manifolds tend to out flow the stock head/cams, which is why there is little documented gains by replacing either on stock head/cam applications.
The intakes for these cars are very new to the market and relatively expensive to other mods, which is why they are not widely accepted. But they are no less worthy of being upgraded than any other component that people upgrade that have been proven time and time again to only deliver single digit hp gains. Especially since they will deliver more gains depending on the other mods (super/turbo/nitrous). Like said above, any gain is very much worth the trouble on the 4.6
ORIGINAL: 2000GT4.6
What you are saying is completely illogical... the only reason to get "extra flow and extra push" is to increase CFM into the combustion chamber, so more fuel can be added (while keeping the a/f ratio the same) and thus make more power.
If your not gaining WHP, it isn't doing anything. IMO there isn't a single 4.6L intake out there worth the money... I have yet to see any car pick up more than 15-20 WHP on a intake swap, and the ones that did were usually boosted/cammed etc cars.
The MM&FF test mentioned above only added something like 13 WHP to a boltons/blown/cammed 2v car, and once they added heads + more boost it still did not significantly outperform a stock intake 2v (the ones I have seen anyway). The 4.6L 2v intake just don't deliver.
ORIGINAL: BostonBruins 2003GT
while big numbers are nice on paper, the biggest benefit is the extra flow and extra push in certain (upper) levels of the powerband....it may be a measly 13 or 15 or whatever rwhp, but a nice lower intake on a ported heads/cammed/full exhaust stang is going to let it breath so much better. We all know that a simple catback on these cars does very little for rwhp gain, but you know it helps your cars breathing/revving...thats the more important part
I read the article, and yes they said that, but the gains are still JUNK. Its easily going to run 1000 bucks by the time you get everything done (intake, gaskets, retune/dyno if needed) and you end up with 13 WHP on a boosted/bolton/cammed car. Whoopde do. no matter how you shake it, your still adding 13 WHP for 1000 bucks, regardless if the other 1000 dollar intakes don't do anything, this one still doesn't do much.
Its simply not worth the coin, there are so many other things you can do with 1000 bucks. Unless your simply loaded and have money to blow, I see no reason to do anything with the intake until your at the forged engine/heads/cams/max boost setup, and even then the gains are not stellar.
#22
This is somthing i have really been looking into due to me being in the market for a metal intake. *plastic one is cracked*[:@] I am leaning twords the P-51 but even foxlake claims a 15-20 rwhp gain on a stock mustang gt. Even if it is bull, i would still feel alot better about not having another plastic intake crack. Plus i would rest a little easier when using a 175 shot of nitrous. Here in the next month or so i will post some dyno numbers for everyone when i get the manifold installed. I'm going to get tuned for a bigger shot of nitrous so i will post N/A numbers and nitrous numbers also.
#24
ORIGINAL: dylanaller
just put a typhoon on mine with a c&l plenum runs great with my 125 shot
#25
ORIGINAL: 2000GT4.6
So if I dyno 10 underdrive pulley sets, and none of them make any power, then I dyno one set and it makes 2 WHP but it costs 1000 bucks you would buy it?
ORIGINAL: tbirdscwd
ORIGINAL: 2000GT4.6
We all know that the bolt-ons for these cars show little to no gains in general. I don't think underdrive pullies are a good comparison though. They are junk no matter what else you have either way you look at it, and you will have to remove them anyways when you go FI. Not like the intake which will net you more HP the more mods you have. If you look back a few years, MM+FF did another test on a built/blown/cammed/heads 2v and gained 34rwhp from just a bullitt manifold swap.
A fully built cammed, heads, boosted car will show much more than 13rwhp from an intake swap. You won't see that much just on FI, your right. It would be much more beneficial for someone with a completely built/blown car to take advantage of the capabilities of this manifold. But on the same token, people are really quick to recommend LTs for the 2vs which have shown time and time again to only deliver single digit gains even on fully built and blown 2vs.
#26
ORIGINAL: tbirdscwd
#27
ORIGINAL: 01GT4.6
the bad thing with most aftermarket intakes (IMO) is they always brag about the gains but you never hear about the losses. It's funny when you look at a side by side graph of before and after and realize that someone just dropped a ton of cash to lose power through out the bad to get a minimal gain at the end.
ORIGINAL: tbirdscwd
Although, I can really see this happening with a Logan or a Reichard, I have never seen any real losses in down low hp or torque with the TFS or Bullitt.
Luke9222
10-22-2015 11:55 PM
09-08-2015 11:50 AM
