PI Manifold & Cylinder Head Swap
Old 04-02-2008, 11:57 AM
jagsfan
jagsfan's Avatar
Default PI Manifold & Cylinder Head Swap
I read the sticky on the installation of the PI intake on an NPI head and I was wondering if anyone has pics or instructions on how to swap the heads and the intake to PI? I will have the PI manifold and heads from a Mustang 2003 (5000 miles) shortly and I want to start to prep for the operation. Any guidance would be appreicated.
Thanks,
Jag
jagsfan is offline
Old 04-02-2008, 03:40 PM
BlackMage
BlackMage's Avatar
Default RE: PI Manifold & Cylinder Head Swap
well the pi intake swap, tells you how to get the manifold off and put it back on, but im sure someone has something to guide you with the heads and timing of the engine
BlackMage is offline
Old 04-02-2008, 03:51 PM
bjh061487
bjh061487's Avatar
you are going to need a head changing kit. i know they have it on steeda's website
bjh061487 is offline
Old 04-02-2008, 04:25 PM
bjh061487
bjh061487's Avatar
found it... http://www.steeda.com/products/4.6L_...anging_kit.php
Old 04-02-2008, 04:42 PM
72MachOne99GT
2010 Blue Ball Award Recipient
72MachOne99GT's Avatar
HAHAH:
20 hours: eh, in all reality, thats probalby about right..i took more, damn amateur
Difficulty: difficult/red warning/terror level high:..eh.. not soo much.. in all honesty, I did the passenger head, and it was a lot easier than I expected
tools....aside from your normal big craftsman set..impact wrench/crank pulley puller/installer is ABOUT all I can recall.
that kit though,
all I see is exhaust manifolds/head gasket.....and it's only one side
you'll need both sides for the intake/exhaust/head gasket/valve cover gasket/timing chain cover gasket...etc..
that list is hoping you re-use A LOT of stuff you shouldnt
72MachOne99GT is offline
Old 04-02-2008, 04:48 PM
jagsfan
jagsfan's Avatar
Awesome, thanks for the quick reply. I will order the kit from Steeda. I am kind of worried about the timing is the 4.6L engines have such tight clearance. I am worried I will bang a valve or piston head. You almost have to be right on.
Jag
jagsfan is offline
uberstang1
12-07-2017 07:10 AM
bconboy
09-24-2015 01:55 PM
Brett Ludlow
09-23-2015 06:59 AM
bconboy
09-21-2015 12:52 PM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: PI Manifold & Cylinder Head Swap
