only one HID will light
Old 05-02-2009, 02:06 AM
HateWhatOwnsYou
HateWhatOwnsYou's Avatar
Default only one HID will light, the other one says f u
ive swapped the bulbs, checked the fuses. i bought a whole brand new kit and the pass side will still not light up.... new bulb, new harness, new ballast... WTF???? the bulb tries to fire, it just flickers for a quick second and dies. ive tried unplugging the driver side bulb and turning them on, but nothin.
what is going on here?????
my old kit worked fine till one night and then the pass side went out. i put the stock bulbs back in till i got the replacement. and still no luck.
Last edited by HateWhatOwnsYou; 05-02-2009 at 02:12 AM. Reason: cuz im hating life
HateWhatOwnsYou is offline
Old 05-02-2009, 05:39 AM
mvr
mvr's Avatar
what brand kit is it?
have you tried changing the position of the ground?
mvr is offline
Old 05-02-2009, 06:52 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
^+1, if the lamp tries to fire and cannot it is likely to be that the HV is insufficient--could be not enough power to the ballast (an overly resistive ground or other connection would cause this), or a bad unit.
cliffyk is offline
Old 05-02-2009, 07:52 AM
LynnBob Mustang
LynnBob Mustang's Avatar
Are you saying even the stock bulb on that side didn't work also when you put them in after the HID stopped working???
If your stock bulb and your HID on that same side didn't work I would think you got a bad wire in the wire harness between the headlight and switch.
I had a problem with my regular high beam not working on the drivers side, even with new bulbs, it turned out I had a wire chaffing through and shorting out on a body panel.
Lynn
LynnBob Mustang is offline
Old 05-02-2009, 10:22 AM
HateWhatOwnsYou
the brand is zentec
the stock bulbs do work if i put them in
i have the ground straight to the battery. i have not tired to move it
i tried my old good ballast(the one that WAS on the drivers side) on the pass side and it just flickers still
Old 05-02-2009, 10:34 AM
steve0914
steve0914's Avatar
i had the same problem and upgraded my battery, now its fine
steve0914 is offline
Old 05-02-2009, 01:21 PM
HateWhatOwnsYou
i guess im an idiot or my car is just effing with me cause i orginally swapped lights, and it was with the same side that was not working....
so when i had the new kit installed i used an old light i had to to test that side. it still didnt work. i swapped the new light and now the drivers side doesnt work...
so i guess it was a light the whole effing time.
Old 05-31-2015, 05:15 PM
jlattan75
jlattan75's Avatar
Can you put stock bulbs into an hid harness?
jlattan75 is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: only one HID will light
