Weird Noise
Old 05-09-2009, 01:25 PM
TheItalianOak
TheItalianOak's Avatar
Default Weird Noise
Ok so I picked up my car exactly a week ago. I noticed a sound, it was more of a squeak that sounded like a timing belt. My buddy swore it was a throw out berring or a u-joint (if that is correct) as soon as you push the clutch in (and I mean a pubic hair push) the sound stops. I hear it when I am driving sometimes but when the clutch is engaged it is gone. Brought it to Ford and they said they found nothing wrong with the car.
Anyone have an idea? Someone said it could be that the clutch needs to be adjusted.
TheItalianOak is offline
Old 05-09-2009, 02:14 PM
01GTDropTop
01GTDropTop's Avatar
Had the same problem on my old 93 Probe GT. It was the throw out bearing.
Just my .02 cents.
01GTDropTop is offline
Old 05-09-2009, 05:06 PM
masterofthepuppets99
masterofthepuppets99's Avatar
throw out bearing
masterofthepuppets99 is offline
Old 05-09-2009, 06:24 PM
zero2005
zero2005's Avatar
is it like a repeating chirp/squeek? if it is, then most likely a throw out bearing, had same problem. fixed when i had my tranny rebuilt.
zero2005 is offline
Old 05-09-2009, 06:52 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
How much freeplay does the clutch pedal have? I have seen a few cars in which insufficient freeplay (cable slack) would let the ToB "kiss" the clutch spring's fingers, just enough to make a noise. Stepping on the pedal would load it up enough so that it stopped.
If you do not have 1" to 1-1/4" freeplay in the pedal then adjust the cable (see here).
cliffyk is offline
bjdutch2005
03-24-2017 03:38 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: Weird Noise
