shave heads, PTV issues?
Old 05-10-2009, 05:56 PM
BlackMage
BlackMage's Avatar
Default shave heads, PTV issues?
ok guys, pi heads, wanna shave them, put em on my 96, w/ CMS stage 2 cams. can i shave them to bump up compression, (not planning on going fi) or should i not shave them? and if i do shave them anyone know how much i could safely go and then also possibly what cam i can get for lift and duration so i dont have PTV issues
BlackMage is offline
Old 05-10-2009, 06:36 PM
10inch Terror
10inch Terror's Avatar
Do not shave the heads...only if they need resurfacing. And then, only minimally. The more material you take off, the more slop in the timing chains,etc. You will already be getting a healthy compression increase just going to the smaller chamber of the PI head. The Stage 2's will be fine for PTV...the Stage 2.5 are a little much and will need to be checked for PTV because it is VERY VERY close. Notching may be needed with the 2.5's.
10inch Terror is offline
Old 05-11-2009, 12:31 PM
lizzyfan
Underboss
lizzyfan's Avatar
If you notch pistons, should the whole rotating assembly be re-balanced?
lizzyfan is offline
MasterLanMan
21
09-16-2015 03:26 PM
EASTIDEE123
09-14-2015 03:52 PM
mustangchef
09-04-2015 08:08 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: shave heads, PTV issues?
