Alternator issues
Old 05-27-2009, 01:11 AM
usermst9673
usermst9673's Avatar
Default Alternator issues
Okay here is the story my battery light came on while pulling into the driveway tonight. When i rev up the engine though the light goes away till it comes back towards idle. Does this sound like alternator is going south? Also what is the voltages that the alternator is supposed to be putting out. Will the battery light come on also if it is overcharging or just undercharging?
I know its a garbled mess of questions, but i am stumped.
Thx in advance for the answers!
usermst9673 is offline
Old 05-27-2009, 01:12 AM
usermst9673
forgot to add its on the 2000 gt!!
Old 05-27-2009, 03:06 AM
boss281
boss281's Avatar
Were you messing with any of the electric connections in your car?
boss281 is offline
Old 05-27-2009, 05:32 AM
devongarver
devongarver's Avatar
look for 14v approx. across the battery when vehicle is running, 11-12v when vehicle is off, that would mean alternator is workign correctly. The alternator should put out a consistant voltage at any rpm, it is the current output that increases as the rpms increase. No matter what at a bare minimum i would expect to see no less than 13.5v while running or i would replace the alternator.
EDIT:Take your alternator off and take it to autozone they test it for free.
devongarver is offline
Old 05-27-2009, 03:39 PM
usermst9673
Well im assuming its the alternator now i get 12.65 when the car is off and only 11.9 when the car is on at idle thx for the help guys! ill post the results when i have it tested for sure at autozone
Old 05-27-2009, 04:14 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Half the time those tests will tell you a bad alt is still good...
Just replace it.. Probably have a bad diode
WhiteFoxGT is offline
Old 05-27-2009, 04:33 PM
usermst9673
Well i just took the alt off and found out its a duralast from the previous owner who i have the name of!!!! Hopefully I can swap it out and get a free one Wish me luck!
Golfsito
10-06-2015 11:02 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
Ghost_Conscience
09-23-2015 02:17 PM
LivingInThePast
09-16-2015 12:20 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Alternator issues
