Could it be the inner tie rod?????
Old 06-02-2009, 05:10 PM
Stangatic
Stangatic's Avatar
Default Could it be the inner tie rod?????
Hello All,
My stang wouldn't pass inspection due to movement from side to side of the front tires. The inspection then says the tie rods failed. Well I replaced my worn tie rods with UPR tie rods/bumpsteer kit last year and I know they are good. However, when I had the car up in the air, I grabbed the wheel and I have about 1/3 of an inch movement when I wiggle the tire back and forth. When I look at the pinion, I notice the lower tie rod is moving in and out of that rubber sleeve by about 1/3 of an inch. Is this the reason I failed?
Some times when I drive the car the wheel with shakes back in forth, but when I am cruising at 60, it is super smooth. Is this part of that possibly worn inner tie rod?
I was told that I could do the inner tie rod my self and that it was pretty easy. is this true?
Stangatic is offline
Old 06-02-2009, 05:11 PM
Donnie's GTS
Donnie's GTS's Avatar
wouldn't that be your ball joint then?
Donnie's GTS is offline
Old 06-02-2009, 05:44 PM
Stangatic
Stangatic's Avatar
^ sorry, I failed to mention that the whole suspension is new except for the rack and pinion and the inner tie rods. When I grab the tire and wiggle, its like someone is in the car turning the wheel back in forth. However, the steering wheel does not move in this case.
Old 06-03-2009, 05:48 PM
Stangatic
Stangatic's Avatar
Anyone?!?!?!?
Old 06-03-2009, 05:56 PM
Saleen9300
Saleen9300's Avatar
Did you/they check the wheel bearing?
Saleen9300 is offline
Old 06-03-2009, 06:14 PM
Stangatic
Stangatic's Avatar
yup, bearings on only a year old and tight as hell.
Old 06-03-2009, 07:48 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
i would say inner tie rod...i just had to do them on my car last year, same symptoms... grab the inner tie rod and see if it has any play without moving the wheel (jack up car first though)
99BlackPonyGT is offline
jrrhd73must
10-02-2015 09:17 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
UrS4
09-30-2015 10:13 AM
mustangheaven
09-29-2015 11:00 AM
gagemcc
09-22-2015 09:43 AM
Quick Reply: Could it be the inner tie rod?????
