A/C compressor cycles on and off
Old 08-18-2009, 07:55 PM
landsteam
landsteam's Avatar
Default A/C compressor cycles on and off
I have a 96 Cobra with only 11,000 miles. The car was in storage for 12 years, The air conditioning is not working that well. You can hear the compressor clicking on and off. I felt the a/c line and it was cold. From what i read this could be caused by low refridgerent. Is it normal to lose some over time? I guess some other part is broken makling the compressor turn on and off?
landsteam is offline
Old 08-19-2009, 11:55 AM
mindtrix2010
mindtrix2010's Avatar
I would say with it being in storage for 12 years it's normal for it to leak some. In fact the seals will dry up a bit if the a/c hasn't been ran in awhile. If your clutch is cycling rapidly on and off, you're low.
mindtrix2010 is offline
Old 08-19-2009, 10:41 PM
Stevecooper
Stevecooper's Avatar
In case reassurance is needed, I agree.
Stevecooper is offline
Old 08-20-2009, 04:16 AM
MineralGrey
MineralGrey's Avatar
actually my AC compressor did the same thing after I recharged the system on my 02 Mustang GT. I assumed it was shot because after my 02 sables AC sparked up and caught fire the AC compressor on that car started doing the same thing cycling on and off rapidly and putting a load on the engine at the same time.
MineralGrey is offline
Old 08-20-2009, 06:11 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Low refrigerant... have it charged and injected with dye incase of leaks
WhiteFoxGT is offline
Old 08-20-2009, 09:07 AM
pikuoff
pikuoff's Avatar
Mine cycled on and off and it ended up being a switch (like $5 part and 5 minutes to change). The dealership put in a new compressor and everything and it kept doing it. Turned out to be some cycle switch that was near/on the firewall.
pikuoff is offline
Old 08-20-2009, 05:51 PM
StockD15b
StockD15b's Avatar
compressor cycle switch on the accumulator is what Pikuoff is talking about.
arent the compressor's suppost to cycle once pressure is met? mine cycles in intervals of roughly 45sec's to a minute .
OP, id get one of those DIY cans with the guage, their cheap and will give u a better idea of what ur lookin at.
StockD15b is offline
Old 08-20-2009, 08:04 PM
pikuoff
pikuoff's Avatar
That's the part...thanks! Mine was cycling on and off every 10-15 seconds or so.
pikuoff is offline
Old 03-27-2015, 06:53 AM
tonysav
tonysav's Avatar
Default AC Compressor cycles on and off
Why would my AC Compressor cycle on and off even though the AC is off? 2005 Mustang Base 4.0. Compressor is charged.
Thanks for any help
tonysav is offline
Old 03-27-2015, 08:15 AM
jwog666
jwog666's Avatar
Thanks for any help
is defrost on maybe? it uses ac compressor as well
jwog666 is offline
mrtrodonet
09-19-2020 03:12 PM
vargas
06-17-2017 12:17 PM
fastbackford351
10-01-2015 12:24 PM
SteelerNation82
09-16-2015 07:11 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: A/C compressor cycles on and off
