Cold/Hot
Old 01-18-2010, 12:32 AM
  #21
fearce65
fearce65's Avatar
Fan turns on. I'll let warm up first, before hitting the street. Then I'll take a look at the coolant temp sensor. Thanks to all.
fearce65 is offline
Old 01-18-2010, 08:20 AM
  #22
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
if the fan is working properly, it wouldnt be the temp sensor....if the sensor was bad the fan would either never be on and the car would run rich thinking its too cold, or it would always be on
99BlackPonyGT is offline
Old 01-18-2010, 11:50 AM
  #23
Z28KLR
Z28KLR's Avatar
Might be a bit of a leap, but, bad water pump? If the fan is on and the stat is good, maybe a problem with circulation.
Z28KLR is offline
Old 01-18-2010, 12:20 PM
  #24
Eagle2000GT
Eagle2000GT's Avatar
Originally Posted by budders
my heat takes like 10-15 minutes to get warm i think its the thermostat. what do you guys think?
If your thermostat is stuck open it will take a lot longer for your car to warm up. I had one stick open in -20 degree weather. Even after a half an hour I was still scraping ice off the inside of the windshield. It was so cold in the car I pulled off the road and stayed in a hotel until a shop opened up the next day. (Why does this stuff alway happen on a cross country trip on Sunday?)
Eagle2000GT is offline
Old 01-19-2010, 04:58 PM
  #25
fearce65
fearce65's Avatar
Thanks for all the responses. I've replaced the thermostat. Flushed the radiator. Fan is working. My next guess would be the water pump. Just a leap here, but would the heater core have anything to do with my problem? Again, just a leap.
fearce65 is offline
Old 01-21-2010, 03:11 PM
  #26
fearce65
fearce65's Avatar
Well everyone, letting the car warm up seems to be working. Thanks for all the help. Now I have to post a new thread.
fearce65 is offline
Old 05-28-2010, 01:48 AM
  #27
fearce65
fearce65's Avatar
Default Found the actual problem
Blown head gasket. Thinking of doing the job myself. Any ideas or words of advice would be greatly appreciated.
fearce65 is offline
PonyUp 281
04-25-2012 09:20 AM
MilitaryDave
SVT Forums
02-27-2012 05:07 AM
Boozshey
05-16-2010 03:18 PM
EaZy DuZ iT
04-08-2010 03:53 PM
jream
08-21-2007 02:50 PM
Quick Reply: Cold/Hot
