humming noise at speed...
Old 01-17-2010, 12:30 PM
joshafmil
joshafmil's Avatar
Default humming noise at speed...
so the mustang recently started making this humming noise when driving at speed. it starts at a low pitch wirl and then as you hit 50-60 its very noticeable. After 65 it gets a lot quieter, but i can still tell that its there.
I doesn't seem to be a tranny/engine noise considering it does not change, regardless of what gear its in, if its in neutral, or if gas is applied or not.
I honestly want to say it sounds kinda like the motive gears i had installed, but this noise is fairly new.
any ideas?
joshafmil is offline
Old 01-17-2010, 03:34 PM
StripeyGT
StripeyGT's Avatar
Lightbulb
Maybe a wheel bearing? Does it come from any particular corner or area of the car? I'd also check your tire pressure and condition.
StripeyGT is offline
Old 01-17-2010, 06:55 PM
joshafmil
joshafmil's Avatar
i cant tell if its coming from an area... it seems to be all over. And ill have to check those... thanks for the input.
Old 01-19-2010, 03:29 AM
T.Richardson
T.Richardson's Avatar
I have the same problem.. I cant seem to find the problem.. I checked everywhere...
T.Richardson is offline
Old 01-19-2010, 10:36 AM
pkwest
pkwest's Avatar
check your Pinion angle and wheel bearings
pkwest is offline
Old 01-19-2010, 11:13 AM
Trackman
Trackman's Avatar
I had the same issue on my old car, at around 90K miles it starting making that whirring sort of whistling sound at the same speeds you mentioned. After a while i was able to figure out it was coming from the front passenger side, changed the wheel bearing and all was fine until the driver side one went...
Trackman is offline
Old 01-20-2010, 07:54 AM
DR.DIESEL
DR.DIESEL's Avatar
if its coming from the rear end then its a wheel bearing or a pinion or side bearing in the diff.it also could be a front hub or a cupped front tire.
DR.DIESEL is offline
Old 01-20-2010, 10:56 AM
0949er
0949er's Avatar
are you guys talking about that noise that you get from like 50-60 MPH that sounds like winds making something "tick" 7 or 8 times? Both my 04 and my 99 made that noise randomly on the highway... like my turn signal "clicker" clicks multiple times for some strange reason at highway speeds randomly (and not constantly). Wierd thing is both cars made the EXACT same sound under the same conditions.... so other people have got to know what im talking about.
0949er is offline
Old 01-20-2010, 04:15 PM
T.Richardson
yep.. the very sound.though its kinda odd, when i press on the gas a little more firm.. it goes away..
Old 01-20-2010, 06:32 PM
0949er
0949er's Avatar
This is my theory:
I honestly think it has to do with airflow over the hood where the windshield wipers are. At whatever speed it is, (including wind speed, ex a 5-10 mph gust towards the direction you are driving, so that your speed + wind speed (towards the car) = total wind speed over car), at ~XX MPH of wind at the right angle/speed blows in just the right spot to vibrate "something". EX. if you held a piece of paper out the window (by both ends) it would vibrate up and down until it ripped. I think this is the same effect we are seeing w/ the sound for our mustangs, where/and what is a mystery haha.But Its somewhere between the back of the hood (closes to driver side) and the windshield. (Possibly wind gets under the firewall? dunno, thats a guess)
But what do I know, I'm not a engineer at fords aerodynamics division lol
0949er is offline
mtgldr
02-03-2024 09:00 PM
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
Quick Reply: humming noise at speed...
